Discuss cables installed below 2.4m??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
bigpaul
Had a customer say to me that there are specific requirements for mounting cables below 2.4m in the 17th edition???
Anyone aware of this. I cant find anything on this. apart from the obvious mechanical protection
Well if you can't mount cables below 2.4m,there must be a lot of tall people out there:confused::D
Where a cable is buried in a wall or partition at a depth of less than 50mm on either side it must be sufficiently mechanically protected against penetration OR Rcd protected AND installed either horizontally within 150mm of the top of the wall or vertically within 150mm of the angle formed where two walls meet or run horizontally or vertically to an accessory, luminaire or ccu. 552.6.6, 552.6.7. This applies to a cable in a partition constructed using metallic parts other than fixings irrespective of the cable depth.522.6.8. Surface run cables do not require RCD protection.
I am guessing coustomer hasnt got an electrical background. of can jump for sockets and lightswitches.
Reply to cables installed below 2.4m??? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
Morning all, We are looking at qualification requirements for inspection and testing to BS EN 60204, all of our work is past the main isolator of...
Looking for some cabling advice for my garden project. I’ve put together this diagram below, which hopefully explains what I’m trying to achieve...
