Discuss Calibrating voltage indicators in the UK Electrical Forum area at ElectriciansForums.net
G
golfpaul
Im getting everything setup for my part p assessment and am wondering if i need to get the voltage indicator calibrated, its the dilog combivolt 2.
Ta.
But you can use the proving unit on a dead site to verify your tester, which you can't do with another tester. One of each for me.
True, but it is in the nature of proving units that they don't tend to give out excessive output. A faulty indicator will often fail to indicate the presence of a hazardous voltage, which is not a fail-safe condition. A faulty proving unit would make you infer that your voltage indicator is faulty even when it is OK, rather than the other way around, so this is a fail-safe condition.
jesus wept what a ridiculous thread
just prove the chuffin thing on a known source of supply....such as the incoming side of the incomer...
any part pis assessor will accept that....caus its perfectly acceptable to prove it using this method...
i`v got...oh about 5 proving units knockin about...
several campbell york`s...a couple of seawards and a martindale..
i`v got several AVIs...
A Martindale phase rotation tester and a Martindale voltage indicator...
loads of stuff like that...lockout gear n all...
Sorry mate - just needed to know if it had to be calibrated or not, i'll get me' coat...
Even calibrated that , too......:wink_smile:
like i says....the incomer (incoming side) will be enough...
dont forget to re-prove the instrument AFTER you have tested for dead...if he asks you to show him a safe isolation....
remember about how to carry out polarity live as well....should he want to see you do this..
its unlikely though that he will ask for anything more than tea n biscuits, a loop test (Ze or Zs)..and maybe your 1/2, 1 & 5...
Reply to Calibrating voltage indicators in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Just thinking about selling MFT's and single test equipment. The idea being I buy stuff from Ebay and sell it on ebay, which I am doing at the...
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
Hi all, I have an unusual issue with a recent rewire I have just completed which I hope you guys can assist with. For background, this is a...
