Discuss Can I piggy back a bath fan light onto another bath light fixture? in the Lighting Forum area at ElectriciansForums.net
skunther
My problem is this:
I have 2 sets of Romex 14/3 in my bathroom - one going to a light fixture, and one going to a bath fan unit (both set into the attic space). I am replacing the fan unit with another that has an integrated light (which we sorely need - the existing light fixture is poorly placed). I don't have a dedicated wire aready run for the fan light though, and do not want to rip up the drywall to rewire the bathroom to accomodate it. Can I simply piggyback the bath fan light to the existing bath light fixture (run the load and neutral from the existing fixture to the bath fan light through the attic), or does this create fire hazard/other problems?
On a side note, if this wiring arrangement is viable, would it also be viable to run only the light switch load line from the existing fixture to the bath fan light (and not the neutral), using for the light's neutral the one that routes back from the fan? Or does the neutral need to be paired with the same hot line that feeds the load?
I would like to be able to have all the lights (including the bath fan light) work off one switch, and the fan work of a dedicated fan switch.
Thanks -
Reply to Can I piggy back a bath fan light onto another bath light fixture? in the Lighting Forum area at ElectriciansForums.net
I’m switching out timer light switches for normal light switches in my bathroom. One went to a light and fan and the second went to another light...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
I'd like to find a timer switch, in a style that looks alright next to decora light switches, to control a bathroom fan. The bathroom fan...
I’m sure this is simple, but it’s confusing me for some reason. I have a line wire coming into a bathroom that used to go to a lighted medicine...
