Discuss Can I use one 12/3 wire to serve as travelers for two different sets of lights in the UK Electrical Forum area at ElectriciansForums.net
Can I use one 12/3 wire to serve as travelers for two different sets of lights controlled by 2 sets of 3way switches, with 2 switch per box?
As stated above the answer is no. What if one set of lights is powered by one phase and the other lights are supplied by another phase. BANG
Reply to Can I use one 12/3 wire to serve as travelers for two different sets of lights in the UK Electrical Forum area at ElectriciansForums.net
I usually always take a picture before disconnecting electrical wiring and this time I did not. I am trying to wire a 3way switch that controls...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
I have 2 kitchen lights, each on its own switch. I would like to re-wire them to where the first switch turns on both lights, but where if the...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
