Discuss Certificate of competency in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Yes I know that. 50 years experience!
My statement was about the fact that the earth wire in T&E was not already sheathed.
I have heard many reasons for not insulating the cpc (only the outer part is technically a sheath), and some believe that if you have an exposed cpc, it will provide better protection to the cable itself, should the insulation on a live conductor become damaged. Personally, I think it's the cost factor :)
How was that worked out?
Damaged current carrying cable ie break in insultion, bare cpc, short between earth a live potentially.
Reply to Certificate of competency in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
As per Part P of Building Regs, once electrical work is performed by a registered competent person, the installation certificate needs to be given...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
A relative recently had an electrical certification done on a rented property. The property was build in 2005 and had previously passed 3...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
