Discuss Characteristics of protective device? in the UK Electrical Forum area at ElectriciansForums.net
Hello fellas. I’ve got a protective device that has sod all written on it apart from the following..... series 3 Henley, pat no: 451302 can someone please tell me what the hell it is?
main cut out .
Cheers mate. Can’t see what’s written on the side though?
[automerge]1568386174[/automerge]
[automerge]1568386200[/automerge]
This is the bad boy here
how many ways is the cu. just put down 60AMP 88 OR N/V.or pull the fuseand then seal with a kiss .most suppliers now when changing to smart meters up on the carrier what in side them.
This is for my niceic assessment. So I’m hoping I can somehow find out what it is
[automerge]1568387409[/automerge]
I’m not there now to pull the fuse but it’s not updated to a smart meter yet anyway mate to be honest
Wish I did have X-ray vision mate for more reasons than I care to mention. It is the first one mate yes, nervous it
just make sure that the choccy digestives are in the fridge. would not want assessor to get soft ,half melted choccy on his nice clean mitts.
As long as it’s a pass mate I’ll take that!
[automerge]1568389966[/automerge]
They are a fussy lot mate! I’m warming up my hands and prepping the Vaseline, f**k the digestives I’m bringing out the big guns
Don't pull the fuse just to read the writing on it, record it as not verified.
If you do pull the fuse and record what is in there the assessor will likely ask you how you found that information out. Cutting the seals and pulling the fuse is going to go down worse with the assessor than explaining why you didn't verify it.
Reply to Characteristics of protective device? in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
I've been installing Type 2 SPDs in consumer units for several years now, and they always come as a pair, connected across L & E, and across N &...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi, need your advise please as need to take supply for Electric car charger from the meter cupboard. This meter cupboard has an isolator and...
