Discuss Chasing? in the Electricians' Talk area at ElectriciansForums.net
N
Noob2013
Hi all
I know most people will say "chase it out by hand the old fashioned way" ☺
But, what is the quickest and easiest way to chase out socket boxes?
Wall chaser? Mini angle Grinder?
My back is pretty knackered so Hammer and Chisel is a killer!
Cheers
Honestly, hammer and chisel for me. Neatest and quickest way for me to take out a socket box in brick. Never heard or experienced anything good about any box sinking kit.
If I can get away with a sdsplus chisel in an empty building then I might use that sometimes for chases too. Not for socket boxes though, too clumsy and can easily shatter brick or make too much mess.
In an occupied and furnished domestic setting then just hand tools. Far too dusty otherwise.
Armeg EBS Back-Box & Wall Chasing Installation Kit ... - NoLinkingToThis
NoLinkingToThis - Power Tools, Electrical, Plumbing Supplies & more › ... › Electrical Box Sinkers
Single and double box cutting kit with unique, Tri-Cut design. For quicker, smoother results and reduced vibration in hard masonry materials. Includes chisels ...
not brilliant on rock hard walls though
Mark the outline of the box/chase on the wall where its going.
Wrap some tape around a drill bit at the depth required eg 25mm.
Drill on the outline you've marked out all the way round then drill inside the outline in vertical lines about 25mm apart.
You'll find it easier to chop out and it should be near enough the right depth.
It's not me being a -----, I have a bad problem which is not work related.
I used to use a scutch chisel and hammer which is pretty good.
Also heard the box sinking kits are only good for thermalite blocks.
The stitch drill method sounds like another good option.
I know ur not a ----- mate, just a bit of sarcasm.
When I started my apprenticeship that's what I had to use, it was a nightmare.
[video]Moorcut Direct Ltd - Quadcut Square Hole Cutter/Fitting An Electrical Back Box In 1 Min 30 Secs | Learn how to quickly earn money online through affiliates and more! - Howtomoneyguide.com ▶▶ hostmaster.howtomoneyguide.com/.../Moorcut-Direct-... Bi Metal Hole Saw Kit - Drilling through metal & wood · Diamond ... Fitting an electrical back ...[/video]
You can even get templates for this method, but by the time you have messed about drilling, you could have had three knocked out freehand.
Reply to Chasing? in the Electricians' Talk area at ElectriciansForums.net
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Hi I'm doing a rewire of an old victorian terraced house built in the 1890s the plaster and bricks are extremely fragile even with a hammer and...
5K
I'm having a bit of a disaster at the minute and would like an honest opinion. I am having a gas stove fitted in the corner of my room and...
