Discuss Cheap gu10 leds on Ebay? in the UK Electrical Forum area at ElectriciansForums.net
B
BillyH
Anyone have any experience with cheap gu10 leds on ebay? How do they compare to the branded versions?
Any info would be appeciated
have you got a link. ? some of the ebay ones are good and some are pants. i would only buy from a UK based company, so as to bed able to get redress if they're duff.
You get what you pay for I'm afraid.
I've installed a number of these El Cheapo LED's and there is around a 30% failure rate within two months. Never had any response from supplier when asked for a replacement or refund, but they are that cheap in comparison it matters little really.
If you want quality, pay for the Philips or similar these are fantastic lamps with excellent light quality and a guaranteed life cycle, however you will have to pay big style.
I've tried cheap GU10 LED lamps on 3 separate occasions and I wasted my money on them all. At least 3 went bang after a few days, leaving black sooty deposits. One didn't work from the off. All had very poor build quality.
Also, the light output from the cheaper ones, in my experience, is far below the levels of th emore expensive items. Some are very poor in lumen output.
In contrast, the good quality (GE I think) ones I have used have lasted many many months and are visibly better built. Daz
Cannot see that much of a saving, branded LED lamps are so cheap now i see no reason why you would fit unbranded stuff.
I dont fit anything i cannot return if it fails, simply because I lose money on it. If a customer can buy LEDs for a couple of quid each then they can buy them and as long as they comply i will install them.
However i tell them up front that if or when they fail, and they call me thinking its my fault. I will charge them a call out fee when i discover its the cheap led lamps they bought!
I've used the China ones from ebay for about 12months and I have had only one failure out of over 100, a refund was issued straight away. Even IKEA are switching all their bulbs to LED, tried 3 they are c**p. LEDs are much cheaper now and so I use LED Hut. Great service and full guarantee. I wonder were they are made?
Just another LED issue. LED flood lights are great, all that light from 10W!!But, has anyone tried to use a separate PIR to control the low energy floods? Not sure if PIRs will work at 10W. You can get LED floods with a PIR but if you want to control 2 lights from one PIR I think that there is a problem,
For what its worth my experience with LED's off e-bay has been buy cheap buy twice! But I stopped buying them a year or so ago so maybe things have gotten better from China .....
I have used the LAP gu10 led's from screwfix for the past year, not had one go yet, probably in excess of 200 lamps purchased in total. Cant remember exact price but sure its between 6 & 7 quid
not tried LED floods on PIRs as yet, but i've fitted several installs with 4 - 6 5watt GU10 LEDs on a PIR and had no problems.
Reply to Cheap gu10 leds on Ebay? in the UK Electrical Forum area at ElectriciansForums.net
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hello All Living room will have 12 GU10s. Can anyone recommend any dimmable bulbs that won't flicker and be around 400 lumens each? I've got 4 in...
Had a customer message me before I went to do a job asking if I could put a new bulb in a spotlight while I was there, so I picked up some LED...
Hi I currently have 4 led bulbs in the bathroom and 3 of them arent working. The bulbs that are currently in are LOMAS LED GU10 220-240V 6000k 6w...
Hi I wanted some advice regarding which downlights company is better from ancell or forum? I have builders doing works in my house but I wanted...
