Discuss Checking a borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
loz
changing a fuse board today, house wired in the 60s with the landing light on the ground floor lighting circuit.
Tested at 250v ins res between the neutral of the 1st floor lights and the neutral of the ground floor lights. Result was 0.04meg ohm. Flick switch for landing light and the reading jumps to >200meg ohm.
Am I right in my thinking that this is a borrowed neutral?
In my head I can see the test voltage going up the upstairs lighting neutral, through athe landing lamp, down the live through a lamp one the ground floor circuit then returning back down the ground floor neutral
Not uncommon my 1970s house was the same, line from downstairs circuit neutral from the first floor. With both neutrals out the IR should be clear. Needs a bit of rewiring.
So what's the test method to prove a borrowed neutral? My tests prove that the neutral of the 1st floor isn't separate from the ground floor circuit, i.e the landing light has its live from the ground floor circuit and its neutral from the 1st floor circuit
If you get zero Meg with one neutral out and the other still connected but this clears with them both out this almost certainly means crossed neutrals.
I work for a medium sized company. Haven't done a massive amount of domestic work on older peopertys. Is a forum not for asking questions and learning, if not what is the point of a forum, we can't all know everything but we can all be willing to learn, do you never ask a question on something your not sure on @sparksburnout ?
Here is a quick drawing to explain my way of thinking as to why I'm getting the result I am with the switches closed.
Your the one changing the board dude, what does your training and experience suggest? You will obviously be a member of a scheme, to be legally allowed to undertake this work, have you asked them??
Legally allowed? there is no way,from the information he has given,to deduce whether or not any legal responsibility is allocated :)
Well if you work for a medium sized company, do they have a supervisor who is qualified to assist you in this? You have a LEGAL responsibility to comply with the building regulations when you are doing a domestic CU change, despite PEG's comments. You clearly do not have much of a clue what you are doing as this is a very common problem when undertaking domestic CU changes, how is this work going to be notified to the LABC? You are not supposed to be asking questions and "learning" when some customer has paid out ££££ for the privilege of you changing their CU!! You are supposed to know how to do it before you start the job.
Yes there is, he has to be a member of a scheme, or of a company who is, in order to undertake work that has to be LEGALLY done in compliance with the building regulations. Doesn't sound like he is, to me??
This is where you are wrong, I however spend most of my time in factory's and served my time on large underground private networks, so if you could keep your incorrect assumptions to yourself that would be great
Quote sparksburnout
Since when has the work associated with domestic installation been restricted to scam membership ? :rolleyes:
The legality is that certain works are notifiable,its entirely up to the installer how he decides to comply with building regs
Scam membership is in no way a requirement for that person and so it should remain so
By the way,membership of any of the clubs would guarantee sweet nothing when installation standards are being assessed,there is possibly higher standards outside of these schemes than there are inside
So who is going to be notifying this CU change to the LABC?
Quote sparksburnout
OK, if you are going to be pedantic, the LABC could have been asked to come out and check it. Do you think this is the case?
The niceic company I work for, why are you trying to turn this into a witch hunt?
If you look at my profile you will see I've been registered on this forum for 5 or 6 years, maybe not as an active poster but diy ers don't tend to hang around for that long do they
Sorry fella,but that statement is wrong,just plain incorrect.
You should qualify why,he has to be a member of any scheme,to undertake what he has mentioned in the previous posts to my quote.
I am not being pedantic simply stating that scam membership is a personal or business decision,non membership may be a reasonable route for his own convenience,its certainly not a segregation of skill set by being a club member
His procedure for complying with building regs, if it is one or the other is none of my business
His skill set and competence to do the job is not our concern either
I always have been underwhelmed by the system that exists regards domestic electrics and regard it as little more than a unnecessary cost to the electrician and of the customer for little or no benefit in regards safety or standards
OK, if we are going to be pedantic, he doesn't. He could get the customer to notify the LABC and get them out to check it. Or, as a member of a registered scheme, he could either do it himself or through his qualified supervisor. Either way it has to be done LEGALLY. Do you really think it's going to happen in this case? P******s me off when I see the rubbish that gets passed off by "installers" who don't have a b*****y clue and have to resort to forums to sort out SIMPLE problems that the customer is paying a so called PRO to undertake.
Hi bud,I am not being pedantic. I am simply stating an accurate fact.
That is,that no legal obligation was implied or required,for what had been discussed in the thread,up to my post.
Whether one revers scheme memberships,despises them or otherwise,there are a huge raft of jobs,tasks and duties,that are NOT legally required,or even shadowed by statute.
Membership of one does not guarantee diddly.
Not being a member,is also,no proof of anything.
I have seen a myriad of scandalous,dangerous,poor beyond belief jobs,performed by schemed up super blaggers.
I have similarly viewed excellent,indeed beautiful work,from folk who have never sat an industry assessment.
I sense that your frustration,may be with the system itself,and i readily share those thoughts.
Try contacting your current scheme provider,in regard to chasing,legally,any person you find having done work un-schemed,or schemed and wrong...i can assure you they will not be turning up the next morning with a judge and CSI team :)
Back open again after a cleanup, please let's keep it on track from now on or it will be closed for good.
Sorry Westy, try now
@hightower, your comments were removed because the latter part of the post was reported for the swearing and that it was seen as argumentative, so it was removed as part of the cleanup mate, also Sparks is now banned for a week for his comments so let's move on and and get the thread back to where it started.
Cheers.
Cheers.
I appreciate that but I first made comment in regards to the original question - thought it could have just been edited to take the 'not so good stuff' out. Oh well.
Hi @loz - sorry to see this has gone off-topic so quickly, but I'm siding with @westward10 on this, your drawing seems to be correct. Lamps in and switches on, you'd get some sort of short neutral to neutral on a borrowed neutral. Flick the switch off and retest and it'll come up clear.
Is that ok ya Drama queen :D:D
So Loz is the problem clear to you now. This situation often occurs with the landing light and often that part of the circuit is wired using pvc/ pvc singles.
fortunately, there's not so many singles seen these days. i put that down to the likes of eHarmony, match, elite, and all the other internet dating sites. gives credence to the saying " a dog is not just for christmas". :mad:
Yeah crystal clear, I had it in my head, just needed a bit of confirmation on proving the fault, before powering the board up, which I had done but wasn't confident in myself. One thing I have learned is that things are so much clearer once it's drawn down on paper.
Both lights have been put on one mob for the weekend and I'm booked in on Monday to put a permenant live into the landing rose as well as a new switch drop and a 3 core downstairs to reinstate the 2 way switching correctly and enable me to split the circuits onto separate rcds. Shame it will be trunking drops but hey ho, can't win them all.
Thank you for your help
...and to lighten things further,it is a little known fact,that most hallways and landings,have multiple singles in them...just usually during a party :confused:
Reply to Checking a borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
I have a client with what appears to be an intermitent fault on the lighting, but trips the power. The installation has a 16th edition board with...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
During some testing I found a N-E IR fault on the kitchen lights of 0.1Mohms. I also found a N-E IR fault on the ring sockets, again 0.1Mohms...
8K
Evening all. I did an EICR recently and then changed a consumer unit. As part of the EICR process I take off around 25% of all accessories to...
