Discuss Combined back box in the UK Electrical Forum area at ElectriciansForums.net
Do you mean 2g and 2x1g all as one box?
or
You might be able to join some metal back-boxes together using 20mm conduit bushes and nuts at a push (with some more nuts as spacers, so the 1g accessories fit side-by-side OK), but if you start with most together like this it is only a 1-gang 35mm-deep box to be added:
If it has to be plastic for fitting to plasterboard easily then you are probably out of luck.
IMO 2 x 1-gang accessories jammed up together always look bad. Gonna be even worse with a 2G in the mix as well. Gaps are needed.
Go with separate boxes. Joining with conduit bushes is good, but use couplers to space them.
they do longer ones for oversized metal faceplates that need a little more space between the boxes. think the short ones are about 16mm and the longer ones 22 -25mm.
That's got to be another Dragons den thing;
Quote from the website;
As with all the best ideas, the Spacer Connect is simple and often followed by the 'why didn't I think of that???'!
Answer is easy as usual,, the price they have to be in low volume production,
Price is per 10.​
15mm Spacer Connect £3.75​
35mm Spacer Connect £4.25​
Conduit Connect £4.30​
Reply to Combined back box in the UK Electrical Forum area at ElectriciansForums.net
Has anyone used or fitted this type of back box ? It is a 1G & 2G
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
Trying to connect a 50 amp inlet box to my Siemens outdoor combination panel 200 amp cutoffs. Can’t figure out where to insert the 50 amp breaker...
4K
https://www.gprokit.com/lever-junction-box/lighting-control-box-flexi-box Anyone used these before? Essentially a Klik box without the added cost...
