Discuss Conduit Selection - Generator Application in the UK Electrical Forum area at ElectriciansForums.net
vonkster
Everyone,
I need a little advice on how to run some conduit from Romex behind drywall around my garage wall to connect to a L14-30 receptacle. A generator will connect to this outlet to power my main panel using an interlock kit. The conduit only will be used in my garage and I feel is necessary so I don’t drill a bunch of holes through vertical 2x4 load bearing framing. Finally - I know running Romex through conduit isn’t typically done, so I will use a junction box to connect to a wire that works well inside conduit. I have a couple questions.
1: What are your thoughts using PVC conduit While metal is typically used, generators have a bonded ground to neutral that doesn’t play well with your main panel neutral/ground connection. Having metal conduit that is also grounded and exposed between the main panel and generator could create a potentially dangerous conductor of electricity across my entire garage wall! Even if it isn’t the “normal thing to do”, having a plastic conduit adds a level of safety I think is appropriate for this situation. What do you guys think? What would you do?
2: What is the best junction box to use that would allow me to connect my Romex behind the wall to PVC conduit outside the wall. Can an “all plastic” solution be worked out so that I can avoid the problem described in the first question.
Of course, I could be overthinking this whole thing which does happen from time to time! ?
Some additional helpful information: The wire needs to support a 240v 30 amp load. I have the right 10/3 Romex selected. I was thinking of running some other wire through 1/2 inch conduit where I can get plastic locknuts for the PVC conduit.
Your thoughts are appreciated!
Everyone,
If it was me I would use all PVC boxes, pipe instead of metal. Way to much bonding has to take place with metal pipe and boxes. Every thing you need is Home Depot or Lowe’s. You probably need a 4x4x4 PVC junction box. Please don’t use 1/2 inch pipe use 3/4 PVC
Reply to Conduit Selection - Generator Application in the UK Electrical Forum area at ElectriciansForums.net
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
