Hi,
i have two electric radiators that I would like to swap. They have different lengths of 3-core wire and to be able to swap them successfully I'll have to lengthen one of the wires. I first thought about disconnecting them from the radiators, but the earth wires are soldered in (the live and neutral are easily removed). So that makes things a little more difficult than I had hoped. I seems the best way to sort this will be to reduce the long wire and add it onto the end of the smaller wire. Is there a choc box type of solution that would work well in this situation? Is there a waterproof way of doing this?
Thanks for your advice!
