Discuss Contactor connections in the UK Electrical Forum area at ElectriciansForums.net
Does it matter what side you connect your supply and load on a 4 pole contactor?? Basically the only place I could fit the contactor was underneath the DB do my supply had to come in the bottom, and there wasn’t a lot of room within the enclosure for 16mm tails so I connected them into the bottom and the load at the top. First time I’ve ever had to fit a contactor, I assumed it wouldn’t matter but wondered if anyone else here knows more on them
Reply to Contactor connections in the UK Electrical Forum area at ElectriciansForums.net
Hello People Our Enphase solar system needs to have the AC supply shut down via the fire alarm contactors local input output unit that has NO &...
A BG fused connection unit, with neon. A boiler. Fuse out. Spur switched off. I was checking polarity after a colleague had 2nd fixed it and...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
Hi. Can anyone offer a bit of advice please. I've got a customer who wants needs an upgrade to their consumer units. It is a bungalow that has a 3...
7K
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
