E
electricbill
Hi - newbie here so firstly apologies if this is not in the correct place or if its a stupid question....
Following safe isolation procedure on a C/U today - on an old re-wireable board, with all fuses removed....checking that no voltage was present using a Fluke T90 I was getting a continuity beep between L & N at the C/U main switch with the the cut out removed. Is this normal? I did not take any readings on my meter so can't be any more accurate I'm afraid.
Any thoughts welcome...
Many Thanks - Bill.
Many Thanks - Bill.
take the t90 and pinch the prongs with your fingers.
it will read through you
^^^ As Tony says, L & N are linked by the coil in the meter.
Continuity between live and neutral at cut out
electricbill,
ImpededLoop,
