Discuss Convert LED ceiling light to plug in in the DIY Electrical Advice area at ElectriciansForums.net
Julesy
Hi. I’m looking to convert an LED ceiling light to a mains plug in. Done this a few times with regular bulb holders, but not sure how to wire the three identical cables coming off the five bulb holders. Any ideas? Thanks
Do any of the wires look any different to the others, like a colour trace. Is it a new fitting.
I would expect one of these wires to be earth, connected to the metal frame - you need to positively identify which one this is, otherwise powering up the light could be dangerous.
You could e.g. use a multi-meter to test between the metal and each of the wires in turn.
The other two wires I'd expect to be L and N, and probably for these lamp holders, it doesn't matter which way round they are.
All identical to the eye...unfortunately...!!!
[automerge]1574022596[/automerge]
Great. Thanks. Will try the multi meter...Cheers
Normally on led lights it has 2 small white or black wires. One is live the other neutral. As for putting a plug on the end I'm pritty sure that you would need to put in some transformer as for example I imagine rigging a 12v light to 240v plug I can't see the light working very long without the 12v transformer. Some lights have the transformers built in but you would have to check that. I ain't really an electrician tho I just have a dabble. Hope it helps
Reply to Convert LED ceiling light to plug in in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
Hi, I need some advice on the wiring for a new ceiling light. I have taken down the original light, and I'm left with the wiring in the image...
Hello. I am in the process of redecorating our bathroom. I ordered some GU10 led spotlights which came with the bulb socket and wiring. For some...
Hi everyone I’m after some advice please. I’m installing some LED profile around a customers bedroom ceiling for some led strip to sit in and...
Hey - so here is a connundrum! I installed a 5-bulb ceiling light (see pic) but when I put the 4w LED bulbs in, they start making a very rapid...
