Discuss cordless switching an outside light in the Australia area at ElectriciansForums.net
been asked by friends of my girlfriend to look at puttinga switch inside her huse to switch a 500w pir flood she has on an out building, i said its a lot of hassle and cost ahving to run another swa cable for it just to switch it from the house rather its current location in the out building.
i ahve suggested using a timer? or are there cordless switching available?
Have a look at this mate,i posted this before.Think it worked out to £115 +VAT.
QVS Electrical Supplies | Electrical Wholesaler
Hi, the guy I installed it for said it was about £150.00 I guess the big problem is, you spend half an hour installing it hand them a bill for over £200.00 then have to argue with them after they go "HOW MUCH!"
B&Q do a pack of 3 plug in remotes with a single controller for around a tenner,sure it's for the diy market but it will do the same job for a fraction of the cost.Just means the flood is on a plug top.
Here you go, try this link well cheep;)
Amazon.co.uk: remote plugs
Reply to cordless switching an outside light in the Australia area at ElectriciansForums.net
Hi there, I have an outside light that is turned on with a switch from inside and would like to change it to a PIR version incorporating an...
Hi guys, medium to beginners experience in electrics. I placed a 250w security PIR light outside. I connected it to the inside first-floor...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Thank you in advance for your help. I recently purchased a home and while removing some built-ins I found that they had a 14/2 wire running...
