OP
MDJ
What's the problem it's only a DB, a 7 day part p course is all you need, stop making a song and dance about it all :tongue3:
Discuss customer from hell in the UK Electrical Forum area at ElectriciansForums.net
What exactly is the problem???
my thoughts too. also on comment below - dropping a cable down cavity loosely will mean its not supported throughout its run and therefore will be a non conformance on install cert. hope you manage to work something out. id assume he will want a fixed price to sort it at this stage which will be a hard one if its a nightmare to sort
Every time on a CU swap, test the installation first then is all is good swap the CU. If anything is bad, then you either get paid for what you've done and leave the old CU in place or sort faults and fit new CU.
This is how i do it and always sees me right.
well.......
2 simple answers here:
1) how many more times do I have to say it....you do a visual on earthing & bonding arrangements and get a Ze before carrying out any work...
2) you conduct a `limited IR test on finals (global or individual)...before conducting a board change & IR between neutrals...this will identify any earth fault & borrowed/shared neutrals in the install...
it isn`t hard...it isn`t difficult and it will save all this crap in the long run...
i keep sayin it...arm yourself with a bit of info before disturbing anything and altering the characteristics of anything...
will we ever find-out what the fault on the faulty / dangerous circuit was / is?????
Reply to customer from hell in the UK Electrical Forum area at ElectriciansForums.net
