O
Discuss Cutting corners or acceptable practice? in the UK Electrical Forum area at ElectriciansForums.net
What voltage?
Is that your apprentice in the background?
What do you think is wrong with it exactly, apart from the lights facing the wrong direction?
Do you crawl round on your hands and knees then usually??Simply the case of having 2 wagos visible - I would always fit a mini JB.
All connections should be suitably enclosed (especially 12V ones) and I do not think a wago is suitably enclosed on its own.
If it were in a junction box then it would be OK.
I certainly would not crimp it, because there would be no option to easily replace the strip once it has failed.
I think you are on the wrong track HHP. That strip will be taking about 4 watts, I don't think there is an overheating issue, and I can't see how the connections would get pulled apart, and even if they did it's just 12V. I reckon its a bit of a fuss over nothing to be honest!! Personally I do what Steve has suggested, solder a bit of bell wire to the strip and run it to the driver. If it fails you will have to re-do it all anyway, unless you always buy short lengths that are ready terminated.Why 'especially the 12V ones' Richard? They are not a shock risk, the terminations may get quite hot, but I can't see how putting in a enclosure would help, although I could be on the wrong track.
As for whether I would do that, no, I wouldn't, ever. They would be far more easy to pull apart by accident than if in an enclosure so the termination is more likely to become compromised and it's right underneath a wooden structure.
Reply to Cutting corners or acceptable practice? in the UK Electrical Forum area at ElectriciansForums.net
