Discuss dashb in the The Welcome Forum area at ElectriciansForums.net
dashb
Hi all.. Ive just joined the forum, been out the industry for a few years, and now getting back into it.. just finnishing my 17th edition course at college and still a bit rusty on some things.. anyway folks, ive got a ceiling rose where the voltage is 180 volts between line and neutral, between line and earth its 240 volts, im surmising thats theres a loose neutral in the lighting loop? can someone point me in the right direction! thanks folks
either loose or maybe a bit charred at a fitting. you are on the right track though. try R1+R2 for the radial, then Rn+R2. if the latter is a lot higher, it's definitely a neutral high resistance.
Reply to dashb in the The Welcome Forum area at ElectriciansForums.net
Hi, I've got a light with a ceiling rose in the kitchen. While rectifying some faults in the house I came across to the light and measure Neutral...
5K
I may have posted this before but not sure if it made it in. I want to install an EV Charger in my garage. The panel is two stories up and the...
In the UK, It is said that the neutral wire is connected to ground/earth wire along the way back to the substation. Ive inherited a setup where...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
