Search the forum,
Discuss Derating factors in the UK Electrical Forum area at ElectriciansForums.net
RJP1
hi i was doing a 17th edition practice exam and got a question about a cable running through a cavity with thermal insulation of 50mm, it asked for the derating factor for it.
i cannot find derating factors in the index of the regs book, could anyone point me in the right direction to find the derating factors eg- page numbers etc
thanks
look in osg appendix 6. table 6B in red osg. page 125. not got yellow copy so may be different
typical IET. should be under I for insulation. if i was looking for long johns, then i'd look under T for thermal.
simple really. 50-100mm of insulation, cable will cope. 100mm -400mm use nextr size cable. over 400mm use next size but 1 as long as it's double the csa. who needs regs?
erm,,, still in training?? May need a bit of guidance??
Guidance for the OP
If you can't find the location of an answer to a 17th edition exam question using the index, use other relevant and related words contained within the question to reference the index with.
Guidance for the OP
^^^ good advice. Look at the key words within the question.
Reply to Derating factors in the UK Electrical Forum area at ElectriciansForums.net
Hi, I have a book on domestic wiring which says that everywhere there is a change in current carrying capacity along a circuit there must be some...
having failed my first attempt at 18th edition exam, does anyone have any tips and tricks on how to study for the exam? being that there is a...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hi I have to run a feed to a CU in the middle of a ground floor flat . Its already got 2 layers of blue board and 100mm rockwool above it . It...
