Discuss DIY Overdrive button replacement for Kia Cerato 2006 in the Auto Electrician Forum area at ElectriciansForums.net
avram2094
Good day all,
I'm looking for some advice about changing my overdrive button in my car.
A little backstory into the situation.
I had to replace my slider indicator for my automatic shifter and to accomplish this I had to cut the 3 wires of the overdrive button to disassemble the shifter assembly.
In an unfortunate situation, the O/D plastic housing was damaged in disassembly so I decided to change the switch and mount it elsewhere, most likely in the centre console area.
The 3 wires are green w/ white stripe (left), red (middle) and black (right).
I then inspected and tested the stock switch circuit to see what could be done.
I realised from the contacts on the switchboard that:
Contact of the black and green w/ white stripe wires means that the O/D is on and,
Contact of the black and red wires means that the O/D is off which results in the illumination of the 'O/D OFF' on the dash.
I bought a toggle switch from a local auto parts store to use as a replacement.
I would really appreciate some advice on how to wire the switch.
Thanks.
[automerge]1587091622[/automerge]
---Edit---
Contact of the black and red means that the O/D is on and,
Contact of the black and green w/ white stripe wires means that the O/D is off which results in the illumination of the 'O/D OFF' on the dash.
you need a 3 pin toggle switch., black to centre, then red to one side for ON, green to other side for OFF.
or try and get the correct part from a car breaker.
Reply to DIY Overdrive button replacement for Kia Cerato 2006 in the Auto Electrician Forum area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
I am installing a ceiling fan in a newly built home. The builders have left the wiring for this purpose. In the electrical box on the ceiling I...
Hello, my house was built in the 1950s and every time I look behind a wall plate the wiring isn’t how it’s shown in any DIY book I’ve read. I’m...
