Discuss DIY Very Big Bang in the UK Electrical Forum area at ElectriciansForums.net
Extend the tails from the top of the switch lol.
But if your going to replace the top portion you might as well rip the lot out and start again
If the original tails were in capping not just plastered straight over the top you might have just about been able to pull a few inches of slack and adopted the isolation switch repair :)
@Dustydazzler . It was just tongue in cheek Dusty , but depends what kind of upheaval is involved for an economical solution. It's up to the landlord really , putting it back the way it was is just inviting another incident.
I got the humour part but in jest it could have actually Been a fairly quick and cost effective solution
I know , not to pretty though. ;)
PS. It just goes to show though that safe zones are not publicised enough.
That could have had a nasty outcome.
can't see the problem with the isolator. the actual isolator body is about 2". or even fit a KMF. they are designed for in at bottom, out at top.
Depends on what the landlord would be happy with.
If I was paying the bill , I would be happy. :)
The landlord might not want some ugly trunking going up his wall. The cable was initially in the wall and he may want it that way again.
@Ricard Has the landlord been told yet? If so then what has he said?
The cable was buried when burying cables like this was loosely acceptable
Putting it back exactly like this even if this was acceptable 10 years back would now not meet regulations
The cables need to either be on a 30ma rcd now or installed in earth metal containment
Trunking all be it a bit ugly will probably be best solution
I think you misunderstand me mate. What I was implying is that the landlord may want the cable back in the wall, so it's not visible. Of course this would have to be done to the regs. I thought that that was obvious and didn't need stating..... It seems it did.
All speculation at the end of the day.
Still waiting to see what the landlord has actually said about the situation.
If the landlord has any sense this should be his preferred option as it would prevent it happening again
True, but then you could say that about all cables in walls.
A certain amount of common sense had to be used when drilling into walls and big electric boxes are on said wall 12 inches away...
Not sure how feasible but how about coming up the exterior in SWA glanded into suitably rated IP65 JB then straigt through into the back of the CU with tails.
Bit of poly filla on the old blast crater and Bob's your aunties brother.
I think we all know the answer to that.
But it will never be told
Old thread but!
He seems to have taken insufficient notice of the fact that the consumer unit is above where he was drilling.
Never advisable to drill directly under, over (or even horizontally) from a consumer unit/accessory as they are supposed to be 'safe zones' for installation of cables irrespective of mechanical protection or capping.
Ask the general public what a 'Safe Zone' is and 95% will not know.
Reply to DIY Very Big Bang in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
