- Reaction score
- 1
I'm about to do an mains change later this week, and unsure if i need to bond the oil fired boiler or not. Its a bosch worcester greenstar, installed around 2 years ago. From the outside plastic oil tank theres an copper pipe running 4/5 meters undergroundto the house. The boiler is getting its water supply from a a joint near the stopcock as an estimate this pipe work is 2 meters, then feeding the radiators the pipe work leaves as plastic likewise for the ho****er. somewhere all this plastic pipe work is joined to copper pipes. Do i need to bond this? and if so where? I've never had anything to do with oil fired boilers before. Also this is on a tt system unsure if that makes any difference
cheers
cheers
