Discuss double insulated (class2) bell transformer in the UK Electrical Forum area at ElectriciansForums.net
hi there
just a quick question when installing a wired doorbell system is there really any need for a bell transformer that is double insulated/class2 to be enclosed in its own seperate enclosure ?
if there is no reason to protect from mechanical damage.
as long as the terminals are shrouded/covered to IP4X, no problem
Reply to double insulated (class2) bell transformer in the UK Electrical Forum area at ElectriciansForums.net
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi. I have a blink video doorbell and want to connect a 12v mechanical bell (pic attached below). I know Blink only allow 16v-24v AC transformers...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
