Andrew Ras
- Reaction score
- 1
Discuss Double socket help please in the DIY Electrical Advice area at ElectriciansForums.net
Thank you so much. I will do all of those things nowThe one at the top put into the COM nearest the wall on the pic. The unconnected brown in the back box into L1 furthest from the wall in the pic (You can see where it has broken off from the piece of wire still in the terminal). I would redo the black also so all that copper isn't showing and check the others.
Reply to Double socket help please in the DIY Electrical Advice area at ElectriciansForums.net
