Neptune
- Reaction score
- 24
OK. I had overlooked the single probe safeguard.
In conclusion, if I found myself in the rare situation where Neutral and Earth had a broken continuity, just touching one of my probes on Live and the other on N/E will provide an indication of power. Enough for me to be suspicious. I was concerned that there would be absolutely no indication of power in this situation and I could potentially be working on a hot circuit.
Yes, once I have done the test I would isolate the power before - test again - then start work. There may also be situations where I am using these tests to identify the Live wire (thinking of a SL in a lighting circuit scenario)
I think you've cleared that up and put my mind at rest Thanks
