Here is a picture of the old one in place
If this doesnt work i will have to call someone out (All my fuse box will be turned OFF while im doing it)
Just need an answer about wires on this one
- - - Updated - - -
Just put a piture of the old stat in place on the tank - dont know if there is a cut out ....!?
yes but it was compliant when installed, its only recently changed to require a safety stat
The reason behind the new safety cutout is that people have died due to tanks boiling over and venting back into the plastic header tank, which subsequently melts and dumps gallons of scalding water on those below.
It's up to you if you want to use a standard stat to test your setup. How are you planning to test your earth loop impedance at the element, incidentally?
http://www.tlc-direct.co.uk/Products/IHST7slashC.html also has the safety.
Dont be mean! lol Hes a DIYer. I would say as he is just doing a like for like replacement and not touching the earth connection it isnt necessary to test it, obviously an electrician would but hey ho, it won't be any worse then it already was
Im just trying to save myself from spending out about £100 for some guy to spend two minutes replacing the stat and finding that my element is perfectly ok
I'm not rich enough to pour money into someone elses pocket for a simple job of two wires!!?
Sometimes common sense can save people alot of money.....
somerset - by looking at the new one i have bought does it matter which side the wires go on? im guessing the plus and minus symbold are for temperature and not +/- wires.
If this works i will buy one with saftey cut out.. just dont want to waste anymore money if it doesnt
It does not matter which of the live feed or the immersion supply goes into which terminal, it is just a switch.
Make sure your have all the bare copper in the terminal.
Obviously not that simple, as you weren't aware of the safety cutout, and you are asking for help from professionals for free.
If you saw the dangerous situations which we see every day due to people trying to save money, you might understand why we ask so many questions.
