A
asbestos789
Hi,
This is my first time post here.
I have had an extension built on my own house in NW London. A double storey side extension and rear Kitchen extension. New Kitchen and Bathroom installed.
The work has been going on since 2011 due to money constraints, but is now finished. I had the electrical work done by an Niceic registered electrician and I have been trying to contact him to provide the required certificates, but have just found out he has gone to live in Spain !!!
I have had another electrian in to have a look who has advised the consumer unit does not meet the regulations as it is plastic. He has advised that I have a plastic split load consumer unit and says that it should be made of metal. The previous electrician installed this approx a year and a half ago !!!
As mentioned there is a new Kitchen/Bathroom and new circuits. The electician I had in a few days ago had a general look around and said that work looked to be completed to a good standard.
I am looking for a bit of advise..
Which type of electrical certificate do i require ? I will be passing this over to building control to certify the electrics.
Do I need to upgrade to a new metal consumer unit ?
If I ask for an electrician to change that consumer unit, will that certificate cover all the work that the previous electrician done ?
Thanks in advance...
