P
Phillip Andrew
Hello
There is a high racking area in a warehouse with 12 aisles of 120m long each which needs the emergency lights upgraded.There are only a few twin head ones at the moment.I have been offerred new light fittings with integrated emergency backup( the cost would be obviously high).What would be your opinion about it,what fitting would do the job at 9-10m hight to keep the costs down as poss.
Kind regards
Ask the electrician you are getting to do the work?
You would need to see the area to say imo
Reactions: DPG
You would need to back up your installation with a design proving that you have met the requirements of BS 5266.
You can take a punt if you wish but when it comes to certifying the emergency lighting installation what will you do with the question about design?
  • Agree
Reactions: westward10
Emergency light fittings
Phillip Andrew,
Nigel,
