- Reaction score
- 8
Hi guys came across something I've not seen before and has me puzzled. I've tested quite a few emergency lighting systems over the years but I'm working in a older church with the emergency lighting supplied from a individual consumer unit wired in Pyro. The rest of the Installation is split over 5 consumer units. Should emergency lights not be on the same consumer unit as the general lighting . I've had a read over the IET Electricians Guide to Emergency Lighting and can't see if this is allowed as surely if there was a fault on the consumer unit with the lights then the emergency lights wouldn't kick in. There is satisfactory completion certificates from the 1980s but no periodic inspection certs / log books as they have new building owners. It also has no key switches with only old 1361 fuses isolating 3 lights per circuit on a 18way board. I was thinking of advising to replace the consumer unit with local key switches. Any input would be appreciated guys.
