Discuss En suite lighting not going on . in the DIY Electrical Advice area at ElectriciansForums.net
Amull91
Guys looking for a bit of advice. Our Mcb on the consumer unit was tripping constant even though nothing was plugged in. Both bedroom lighting and en suite lighting come under this MCB. However until recent both bedroom lighting remain on and the mcb doesn’t trip but the en suite lighting won’t come on at all ? Is there any idea how to fault find before calling in a spark .
Cheers
A
If the mcb is tripping then a significant fault has occurred which has now caused a failure to the ensuite part of the circuit. You are going to need an electrician.
Reply to En suite lighting not going on . in the DIY Electrical Advice area at ElectriciansForums.net
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
Hi all, Wondering if you could offer some advice please. I carried out a small outdoor lighting project today at a commercial property. 4 lights...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
