Discuss Explain ''code 4'' in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
DanBrown
Hi Guys,
Not used to filling in certificates for jobs just yet, so i have a question for you. I have heard about people putting in code 4 on the test sheets, can you just explain code 4 and explain why and when you use it.
Thanks, all responses are appreciated...
Hi Guys,
Basically what it states "Does not comply with BS7671"
When you carry out a periodic inspection you would be carrying it out in accordance with the current Regs (Now the 17th edition) but when the installation was installed it could have been installed to the 15th edition (which was in use at the time but was not a BS standard at the time) so the installation is not complying with the current BS7671.
Hi Guys,
Dan here is a link to the Electrical safety council best pratice guides. Guide 4 will explain info on the codes used for PIR's
Best practice guides | Electrical Safety Council
Hope this helps
Warren
Reply to Explain ''code 4'' in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys Completed an EICR yesterday. One of the Sockets Radials had no CPC so R1+R2 plus Zs could not be not be completed. Does anyone know the...
I am just curious, can Wireless Power Transfer (WPT) be used to power high-powered appliances such as washing machines, dryers, etc.? If not, I...
Hi everybody, I've been asked to do a EICR in a commercial property, So i popped in to have a look on my way home quickly and found the lighting...
Hi guys. Can someone explain what is this? Where are the CPCs connected? I think the black cable connected to the MET have something to do with...
Good morning all I have a summer assignment that I need to have ready before the 4th of September and I have 4 tasks that I have yet to complete...
