Discuss Extension in the DIY Electrical Advice area at ElectriciansForums.net
Gingernut
Hi, my son's bedroom has no plug sockets at one side of the room. But I'd like to plug a bedside lamp and some LED lights in at that side of the room. Obviously I can run an extension lead from a socket on the other side of the room.
Would it be an option to run some cable or flex with a plug on, from the socket and attach a double socket at the other side of the room to use?
Any help and advise appreciated.
How is a plugged in double socket better or preferable to a plugged in extension lead ?
It is an extension lead! But possibly (though not stated), the OP intends to clip it to the wall or skirting etc?
Because I already have a double socket, cable and trunking so it saves me Ā£20 on a 4/5 metre extension. If it is safe to do and I use the right cable.
[automerge]1586686875[/automerge]
Just wanted to ask the cable to use and the safest and correct way.
Reply to Extension in the DIY Electrical Advice area at ElectriciansForums.net
Hi, Iā€™m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
Hi Wonder if any one could give a rough estimate for first fix electrics for a small 4x4 side extension? Would involve moving consumer unit same...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
