Discuss Fan isolator turns off light too? in the UK Electrical Forum area at ElectriciansForums.net
SiJohn
Hello all,
Just wondering if my en-suite is wired correctly .
There is a timed extraction fan and bathroom light in there .
There is an isolator switch outside the door. When you turn off the isolator the light stops working too.
Is this correct?
Should the isolator not stop the fan only and allow the light to still come on?
Any help appreciated
I don’t know the Irish building regulations, but this is extracted from the Electricians Guide to the Building Regs. I would imagine the applicable Irish regs are similar, Scottish building standards certainly have a similar statement.
“An extractor fan supplied from a lighting circuit for a bathroom without a window should have its own means of isolation; if it does not, the replacement or maintenance of the fan would have to be carried out in the dark.”
No window in the room, the fan needs to be isolated independently from the light. With a window do what you like ?
Changing the operation so the fan isolator doesn’t isolate the light is possible but without knowing how it is wired now I would be guessing on the safest and easiest way of doing it.
Thanks for reply, that makes sense. My en-suite has no windows so I think perhaps it’s not set up correctly.
The isolator has a permanent live going to the fan, then two twin and earths ( one going to light and fan and then one to the shaver outlet)
Reply to Fan isolator turns off light too? in the UK Electrical Forum area at ElectriciansForums.net
Hi, have an old bathroom fan. Which has two wires the black and red (line and neutral). The fan has no isolator switch and was powered when the...
Hi I replaced a Flash immersion timer with an apt one today and it seemed straightforward but just wondering should the light on isolation switch...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Good afternoon everyone. I have fitted an extractor fan in my bathroom with an overrun timer, to start when the bathroom led lights are turned on...
8K
