Discuss Filling in test certificate in the UK Electrical Forum area at ElectriciansForums.net
Gazthesparky
Just a quick couple of questions its a Friday and now sitting doing paperwork with a couple of beers.
Im filling in a certificate to cover a consumer unit change and having a mental block.
There is a 3phase supply coming into the building and then the flat I was working in has a 6oamp supply.
noting the supply characteristics is it the 3phase supply that you note down and then later list the 60amp sub main or is it the 60amp sub main I list as the supply characteristics
This is the supply would you agree that it is a TNS supply ? tested line to earth and it was o.17 ohms and Line to Neutral 0.19
The earth to the flat is bolted off of the metal trunking that comes from the supply head
cheers
cheers
thanks for that just needed some clarification and defiantly agree the head needs binning but thats not my problem I'm just doing work in one of the flats its the factor company who's responsible for the communal area/supplys.
A lot of the tenements in Glasgow are supplied like this
Reply to Filling in test certificate in the UK Electrical Forum area at ElectriciansForums.net
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Agent contacts me with an urgent request for a CU upgrade in Camden. They send over an EICR done the previous month and I have a quick skim. All...
10K
Hi guys, first time posting, please bare with me! I have an old test chart as shown in the pics that i would like to get running. Everything...
Interesting situation has come up. I have a client who rents out portable toilets - higher end ones with proper flushing toilets/urinals that are...
