Discuss flood light cable in the Lighting Forum area at ElectriciansForums.net
APE37
Hi guys.
Just wondering if any one can help on a small job I have, that I will be using as my minor work for upcoming assessment.
Customer wants a flood light over their front door, was going to put a switched fused spur next to a socket in the bedroom run along in trunking for around 2meters, drill through wall and place adaptable box on wall outside then place light and run flex in to box with compression gland. Unfortunately the customer don't want trunking run along inside from the spur. ( all sockets are surface), so was thinking of coming off socket with spur and drill through wall through the back of the spur and run cable on outside to adaptable box. Just wondering if there are any recommendations for cable other than Swa. I was thinking of some black flex clipped to wall, but I think I have read somewhere this is not allowed maybe I have mis read this? just wondering if some one can put my mind at ease and confirm flex would be ok or is there a different type of cable that is not so intrusive like swa.
Thanks for any help.
Cheers
I used MI when I fitted one on my house, stripped bare after it left the wall. You could use conduit or outdoor rubber flex H07RNF.
You may also need to consider reg 521.11.201, if the cabling runs above the doorway. Plus it would not look rather nice, I would prefer to conceal the cable in some way, be it inside or outside.
I would go back to the customer to clarify what they will accept!
If you use flex, it will sag over time unless you use loads of clips
If you use Hi-Tuff / NJJ - this will need fewer clips
If you use conduit - it will need fewer supports
Give then the choice!
Reply to flood light cable in the Lighting Forum area at ElectriciansForums.net
What cable would you use to connect this light through a cavity wall to a FCU the other side of the wall? I am thinking, 1.5mm² 3 Core NYY-J...
Im running a ring main for all my sockets using 2.5 cable....as an after thought i was thinking to spur off one of my socket outlets and run up...
I'm looking at putting up & down lights onto a solid brick wall (1900 semi detached house) What's best way practically and aesthetically to...
I have a spare 2.5mm 3 core flex cable. Can I use it for an outdoor light? It will be connected a junction box that's already supplying...
I need to install a floodlight for outside now its dark. Its just inside the kitchen wall to connect to the electrics. My simple idea is run a...
