Discuss floor boards in the Australia area at ElectriciansForums.net
I tend to use a jigsaw to cut the board, both down the grooves if it has any and across the the board itself if I only want a small section up, going where the nails are to be sure you're on the joist.
circ saw or multitool fein type but just a cheapy one. most houses I have had the fortune of being in after the central heating so they had been up anyway and like Billy said not too well taken up either :D
I Have a cheapo feintool type tool from Aldi and so far it's been great! I will probibly get the bosch equivilent when it dies. Great especially if you need to lift close to walls ect.
Rich
oh and try and lift a board where two floor boards meet, that way you can set your circular saw at the right depth, and you wont cut through anything that may be running across the joist in a shallow notch such as a pipe or some previously installed ring mains, lighting cables and shower feeds, not that i have ever done that of course :blush5:
Whatever you do dont ask the plumbers to do it!!!!!
there are several ways of finding where plumbers have lifted boards.
1. water marks on the carpet.
2. creaks when you walk over.
3. bloody great draught from under floor.
4. 4" nails in boards, impossible to remove without destroying the board/s.
5. notches in joists big enough for a bus, rarely within the prescribed zones.
6. burnt and blackened joists and cables.
7. hot pipes threaded through, or sitting on, cables.
LOL tel, you also forgot the dam gas pipe that they lay under an existing nail hole that had been in the board for years and some unsuspecting person like myself 14 or so years ago goes to sort out the squeaky board and yep a second later hears a funny noise and the smell of an expensive Friday night emergency call out from British gas. never got charged though as he had some choice words to say about the gas fitters :)
Reply to floor boards in the Australia area at ElectriciansForums.net
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Hi All I wanted to ask a question about the reference method. Passing wiring through holes made at 0.2-0.4 of the joist span. The cables passes...
I am a complete novice when it comes to electrics but I have recently bought a grounding mat and so I've been doing some measurements and I'm...
Hi guys. It would be really useful to run this past you and get a consensus/input from you for what would be a realistic amount to charge for an...
Hi Guys, sorry if posting in the wrong section. I am due to start 2391-52 course soon, and there seems to be from what I have found out, a 3 phase...
