Discuss Flush mounted CU in the UK Electrical Forum area at ElectriciansForums.net
goasis
Evening all, have yet to fit a flush mounted CU, may have one in an upcoming job, a quick google seems to only throw up Hager boards as an option. Are there many other options out there, only got 6 circuits but would ideally like to leave a couple of spare ways, SPD, prefer RCBO's.....
Is there any reason you couldn't fit a regular board, if you had the correct depth in the wall?
Only a site survey can tell you what will fit in the hole and look Good.
there are no technical reasons to fit one or the other, it is all about looking right.
Reply to Flush mounted CU in the UK Electrical Forum area at ElectriciansForums.net
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Hi fellow sparks, I've just started out on my own so I'm spending a lot of my time trying to find out the correct way of doing things of...
Hi all, been reading around this and i have to admit ive quickly gone out of my depth as regards EV chargers. The charger in question is a...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi, I have a dual RCD board made by Hager installed a couple of months ago. It is high integrity, which I understand to mean RCBO’s can be...
