Discuss Freezer Tripping Rcd in the Electrical Appliances Forum area at ElectriciansForums.net
Y
YTSOxford
Hi all,
I have a TT system at the moment and a freezer trips the rcd on start up. I am rewiring and the old 100m/a rcd board is still on, it works fine on this and starts up, and if you leave it for a few minutes and plug it into the new board afterwards, it does not trip the new board.
what would you guys do? It was connected to a socket outlet plate before, with a 30m/a built into it and this did not trip, is it possible to have this on a dedicated circuit? Even though it would be mainswitch side - so no rcd protection to the plug, (surface mounted)?
hi mate - i have tested the new boards RCD and all is fine, not sure about the old RCD intergrated socket that it was plugged into tho, it probably has had it. I do remember the builder saying he got a shock of the old wiring, but then again he sholuld be leaving that to me! :-0
If the freezer has an auto defrost function then this is possibly causing it to trip the RCD. Have found this with a number of freezers they have a heating element which operates about every 24 hours this becomes porus drawing in damp or it is slowly failing causing it to trip the RCD. Have also had similar problems caused by temerature probes
Thanks. That probably is the cause just not sure how to solve the problem.
Hi all,
If the route the cable takes does not require RCD protection (surface mounted or buried more than 50mm in wall) the regs state that RCD protection can be omitted for sockets labelled for a specific item of equipment.
Supply is TT so doesn't it need a RCD at front end if disconnection times can not be met
Yep. Missed that bit
Reply to Freezer Tripping Rcd in the Electrical Appliances Forum area at ElectriciansForums.net
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi, I have a job for a customer, the consumer unit is an old 3036 board and there are several holes in it giving access to live parts, I can...
