Discuss Fuse Downgrading in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
J
jdd
Is it acceptable to leave a 2 core 10mm2 MICC cable supplying an upstairs flat on a 100A suppliers fuse? (Maxing demand is acceptable and disconnection times are within tolerance.)
No, existing installation. Just wondering when there is no space in the meter box for a switch fuse. I come across this every so often when carrying out periodics.
NO. Without fusing down, you would exceed 3m which the supplier will say is the max unfused.
Also regs say max of 3m back fusing.
Is the pyro the property of the DNO. I know around here many flats were serviced by DNO in pyro. I have had faults on these on occasions and DNO changed them for hybrid concentric.
Reply to Fuse Downgrading in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Had UKPN come out to a property recently to upgrade the main fuse from 60A to 100A but when they arrived they said that the supply cable which he...
Got an EV (Nissan Townstar EV) in my house, has a Zappi EV charger installed (by myself) and notified via ENA form to Scottish Power energy...
Hi all, My question relates to the omission of overcurrent protection (specifically overload and fault protection) at the origin of an...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
My customer has had a completely new supply installed to his garage. The DNO has not put a fuse in the cut out though. I'm guessing he needs to...
