Discuss fuse mod which disconnects neutral in the UK Electrical Forum area at ElectriciansForums.net
spidersparks
Evening guys, I got a job at the moment that requires a bit of scheming, I have some gas fired fan heaters that need to have a permanent supply for the fan inside them so they don't over heat etc, they then switch on from a control wire simple stuff, what I need to do is have a local isolator for each one but the the permanent live can not be turned off unless it's being serviced and this is in a public place where people fiddle with things! What I'm after doing is to put in a single mod plate in with a double poled isolator for switching just the control wire only and I'm sure I've seen these and this is what I need help with locating, a fuse carrier which when the carrier is removed it disconnects the neural as well as removing the fuse, now I'm hoping I haven't dreamed these up and making a plonker of my self but if someone has seen one and can point me in the right direction appreciation and plaudits shall be received
Many thanks in advance
David
If you are trying to fit a mechanism in a single gang plate then you could fit a double pole key switch for maintenance (though they are not isolators afaik) and a single pole switch for the control wire. If you need something fused then use a triple gang single plate and add a fuse carrier.
Reply to fuse mod which disconnects neutral in the UK Electrical Forum area at ElectriciansForums.net
As per normal I was in a rush and didn't get enough information. I was working in an apartment that didn't have any power and when I went to...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Good afternoon all, I have been asked to look at a problem with a bolted neutral but no one seems to know what exactly is the problem. SSE...
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
