Hi all,
I'm pricing a job which involves re locating a fuseboard from a utility room, to garage wall backing on to utility. The installation is brand new build (fully installed and tested by others) with ammendment 3 compliant board.
Board is mounted at 1.2m at moment in utility and can go at a higher level in garage so as not to alter any length of cables. All cables including tails are dropping from above in cavity (timber framed) wall.
Job simply requires cutting hole in plasterboard above current fuseboard, then drilling through garage block wall to feed cables through to back entry board in garage.
Obviously i need cable identification in utility where cables are dropping in cavity then passing through wall.
My question is.....would I need to re test the full installation? Only asking as this would alter the quote i'm giving.
Personally I don't think it needs a re test, as I am not altering any circuits (cables will be exact length), not adding any circuits, and re using same brand new fuseboard with all circuits in same order.
Any thoughts???
Any thoughts???
