J
jo4nny8
Hi All
Im looking for a little bit of general guidance with regards to prices i should be paying for works.
Without giving to much detail, I run a bathroom and kitchen company and have used my current electrician for about 4 years on and off. This year hes had a lot of work off me (in excess of £5k i would think)
Im just slightly concerned by the (what i think) high prices im starting to be charge for work and wanted a little idea if you guys think its about right or way over the top.
If i give a few examples can you guys give me a rough idea of what you think is a reasonable price range??
Lets assume everything within the existing installation meets current regs, bs7671 etc (any remedial work required is priced by him and charged to the customer)
Bathroom.
Generally our bathrooms consist of:
Remove pendant light / similar light in centre of room,
Install 3 / 4 chrome downlights (i supply)
Install either 1 x shower light or 1 x wall mounted extractor (depending on which depends on amount of downlights)
So i supply lights and extractor
He supplies cable, spurs, backboxes, pull chord or light switch depending on what is currently installed - general consumables really
Any ideas on a rough guide price??
Kitchens.
Slightly more involved really but i will give a general perception.
Change 5 x double sockets (straight swop)
Install feed for chimney style extractor
Install feed for oven, and hob (13a double plug)
Install feed for dishwasher
Install feed for washing machine
Install feed for tumble drier.
With regards to the above they are normally there and so it is merely extending cables and moving sockets into cupboards etc (were not talking about installing new rings mains etc)
Install 6 x under counter lights (i supply and install these he does electrical connection as the lights are 12v with a transformer pre fitted etc)
He supplies cables etc and sockets.
Any idea of a rough sort of price??
Can people also advise on roughly what percentage of installations they go to that require remedial work to bring up to current standards? For some reason i am finding every single job we does has to have some sort of rememdial work - ranging from bonding on gas and water being increased from 4-6mm -10mm, to full consumer unit changes as theyre still using rewirable fuses etc)
Now whilst im reasonally technical, when you start talking about technical things i get lost and i dont want to be either getting screwed, but also dont want my customers thinking were ripping them off if work is being done that doesnt need to be.
Can anyone help me out?
Bathroom.
Kitchens.
