Discuss Global IR testing on RCBO populated CU in the UK Electrical Forum area at ElectriciansForums.net
Crabtree single module
That shows the trip part as the 'X' crossing the live path just after the switch symbol.
I think it is often seen that a MCB/MCCB is shown just as an X on power schematics.
What are the practical differences between the two schematics? I don't fully understand either, but this is a great alternative to painting the kitchen.
I think it is just one of conventions.
Originally schematic parts would show things representative and easy for humans to draw, like coils for inductance. Then CAD and pen-plotters came along and they were simplified to boxes to make it ease for machines to draw.
Is a neutral busbar worth the additional space required for 2 module RCBOs?
That is a fair point.Often the space is, nt available in older installations. In newer installs space is generally a non-issue. But I can assure from experience that once you install a CU with dual module rcbo, s you will find yourself seeking to "make the space" on your next install. I find installation time is nearly halved. Its a bit like comparing a WAGO push in to a traditional connector. They are also very convenient for testing and for faultfinding.
Reply to Global IR testing on RCBO populated CU in the UK Electrical Forum area at ElectriciansForums.net
Did a check on a ring circuit, due to board having to remain live I did it at a socket.. Was an RCBO, had checked RCD side and all tested ok...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Doing some testing today on a Wet Room installation. Fed from its own small CU. And consists of 2 x seperate 50A (for 10.5kw shower) circuits...
