Simon Wade
Hi all
Recently I moved a grid switch fron inside a cupboard to the outside of it, basically we just extended the existing wiring ( via a new adaptable box with klippon terminals etc) to the new grid switch.
The old switch grid had neons that worked fine, since we have moved the switch the neon no longer work properly.
Both old and new Grid are MK.
We have checked all connection and have found nothing wrong.
we have also tried swapping neons and replacing the new ones.
Also does anyone know of any grid neons that will work if there is no neutral connection available?
