Discuss Heat detector only fire alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Thats why i always install Gent systems. with a gent addressable key switch next to the panel........
One of those!
in the event of smoke machines being used, one turn of the key and the affected areas switch from smoke to heat. it also puts a fault onto the panel to remind you to switch it back once the smoke machine gets put away.
Some local authorities take a very dim view of such things when it comes to getting the place licensed. This varies wildly between local authorities though.
I know of one theatre which has a switch next to the prompt desk which isolates the smoke detectors for 1 hour at a time due to a stroppy licensing inspector not allowing a normal isolation procedure.
These dont isolate or disable, they simply switch the state of a pre determined group of detectors from smoke to heat
Reply to Heat detector only fire alarm system in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
