Discuss Help - connecting up single phase motor in the UK Electrical Forum area at ElectriciansForums.net
I have been asked to connect up a single phase motor in an extractor fan but not sure of connections and don't have data sheet
The fan is a Nicota DDM 9/7
A six core cable comes out
Brown and white joined to one connector
Brown - capacitor linked to this
Black - capacitor linked to this
Brown
Earth
Would I be right in saying the live should go to the connector with brown and white and the neutral to the other brown?
(I am a spark to trade but this isn't what I am use to dealing with so unsure
The colours don't always follow a standard (apart from green/yellow), look for indication of the windings such as U1, U2, Z1, Z2 if it's single phase, determine required rotation direction then work out your wiring scheme from there.
Reply to Help - connecting up single phase motor in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi, I am looking for a connection diagram or sugestions for a 2.2Kw single phase motor to drive a compressor. The spec plate shows that it can be...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
Hello Everyone -- So, I am looking to buy a used 5HP 3PH 208 V 10 inch Table saw --- (Motor Plate Data in Image) I am a DIY'er and in...
