U
ukpablo
Had a look at a job for a hot tub install, seems fairly easy, however no room on existing cu.
any ideas?
should i run tails into henley block, tap off and use a small seperate cu??
load is only about 4.5 kw so 32 A breaker ok!
is this acceptable??
any ideas would be great
:confused::D
yea, would be standard rcd protection, maybe a two way small crabtree board?
Otherwise its a new cu for the house and more expense for customer, which they will obviousley will not want.
Hot Tub CU
Electrical Tools and Products
ukpablo,
ukpablo,
