OP
Discuss How badly does my house need rewiring? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As already mentioned, could just do with some TLC or the main insulation of the cables could be as you say going brittle, which means attempts to update the faceplates or even repair broken ones could result in damaging the cables even more.
Didn't see any RCD on the property, that would help with safety providing there are no faults. Also remove all stuff from around the electric box, service head etc that could catch fire.
There appears to be a separate cct for heating of some type i assume (the single way wylex i think)
Worth spending a little to determine how good / bad it is before deciding to spend thousands on a re-wire as best case is that the wiring will give another 5 years and you update the CU to latest type giving a much safer install, oh and get some smoke detectors in there as well
Nathan that isn't the answer mate, it's a bodge really. Get your folks to get a test done and that will tell what needs to be donewhat if I where to temporarily use sleeving to prevent split insulation in the boxes and lights causing problems? there is the problem that temporary fixes often become permanent.
Reply to How badly does my house need rewiring? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
