Discuss How do I charge 2 12V leisure batteries connected in series from my starter battery? in the UK Electrical Forum area at ElectriciansForums.net
Re: How do I charge 2 12V leisure batteries connected in series from my starter batte
the set up looks something similar to that used in rac vans, Firstly you cannot charge a 24v set up from a 12v alternator well you can but you need a lot of heavy relays and it all gets very complicated, second remember that an alternator on a vehicle must run at a minimum or 1500 rpm to put out charge so it isn't going to charge on tickover and finally there is no need to fuse the negative side of the supply as most negatives are in contact with the chassis anyway ( negative earth) as others have said either use a small genny or go to an auto electrician,if you have a go and it catches fire you may find your car insurance not paying out.
indeed - you have to remember that there may well be multiple live connections off the battery
Yes but in this instance there seems to be a single circuit added where both live and neutral are fused which is not required all live connections from the battery should be fused normally the terminal clamp also has several large fuses built in so that all circuits are protected as close to the source as possible. Also its very rarely necessary to connect back to the batteries negative as the vehicle chassis should be used,
Phil,
When extra alternators are added to vehicles to run auxilliary devices, such as freezers in an ice-cream van or RF amplifiers in TV satellite uplink trucks, they are usually fitted with pully ratios that ensure the alternator will run at a suitable speed to provide rated output whilst the engine is at tickover.
There is most definitely a need to fuse both negative and positive connections in certain circumstances, for the very reason Sean explained. And the example in the picture that ahtyrrell commented on is ironically a perfect example of exactly when it is necessary and has been correctly done.
for what it's worth I think those pictures generally show an installation that has been carried out by someone who does know what they are doing, the invertor is of poor quality and there's a fuse cover and battery terminal cover missing, but the mounting of the fuses, the containment of the wiring and the general layout looks very good - nothing is perfect in this world
Reply to How do I charge 2 12V leisure batteries connected in series from my starter battery? in the UK Electrical Forum area at ElectriciansForums.net
I will be putting together 2 x 12v lead acid battery connected in series (24v basically) backup power for Internet connectivity (routers/wifi etc)...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
Hi, My camper has a new 12v battery and I have wired up a split charge relay with a 100 amp blade fuse near van battery and a 100 amp blade fuse...
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
Good morning all. Before I start I am not an electrician and am relatively new to this topic. Current set up Axpert 5.5 Kw inverter, 7 x 420...
